mukilupo Posted May 25, 2008 Report Share Posted May 25, 2008 Hi, ordered Blue H3 bulbs for GTI,on arrival i noticed the bulbs where 12v/100w instead of standard 12v/55w.Can they still be used or is there going to be a problem?Many thanks. Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 25, 2008 Report Share Posted May 25, 2008 Theoretically, If your wiring is not upto it, You'll be causing a fire... However most modern cars these days are OK to use super high power bulbs. Quote Link to comment Share on other sites More sharing options...
g-man85 Posted May 25, 2008 Report Share Posted May 25, 2008 I'd be worried with the increased heat output and the fact they could possibly melt the headlight plastic, which isn't a cheap fix. Quote Link to comment Share on other sites More sharing options...
nfbr Posted May 25, 2008 Report Share Posted May 25, 2008 I'd be worried with the increased heat output and the fact they could possibly melt the headlight plastic, which isn't a cheap fix.Yep, That aswel. Quote Link to comment Share on other sites More sharing options...
mukilupo Posted May 25, 2008 Author Report Share Posted May 25, 2008 Thanks for the info. Quote Link to comment Share on other sites More sharing options...
