LINCOLNSHIRESLUPOGTI Posted July 24, 2007 Report Share Posted July 24, 2007 Today the passenger door locking has gone funny.Works exactly as it should with the remote so no problem here.When inside and I press the "lock" button on the drivers door, everything locks then the passenger door lock immediately unlocks. Tried this several times, opened and closed door a few times then tried locking again...still broke!Stripped door down tonight and thoroughly cleaned door handle mechanism, adjusted the door pull cable (was a little slack anyway and exterior handle was not opening the door until nearly full travel) unplugged door locking motor and cleaned all connectors (they were spotless anyway). All back together and no difference.So I now believe it is a relay fault. Can hear it actuate behind fuse box and then re-activate to cause passeneger door to unlock (the fault).1. Any suggestions, relay buggered maybe???2. Is the relax behind the fuse box or is the noise of it working just sounding like it is there? Quote Link to comment Share on other sites More sharing options...
REDGTI Posted July 29, 2007 Report Share Posted July 29, 2007 Mine's done exactly the same thing, its been like it for a few weeks and randomly works fine from time to time.If you push the lock down yourself it locks fine but pressing the button just makes it pop backAny ideas? Quote Link to comment Share on other sites More sharing options...
LoopyLing Posted July 29, 2007 Report Share Posted July 29, 2007 A Temporary cure that works for me: Turn engine off the lock un lock lock un lock a few times or force the button down then hit the lock button a few times.Vauge i know... Quote Link to comment Share on other sites More sharing options...
