RallyeBaz Posted May 20, 2007 Report Share Posted May 20, 2007 Bought some 2nd hand wheels which came with good 195 50 15 tyres. Fitted them to the car and no problems with steering shake after 56 mph.Had to change the front 2 tyres as they were catching the arch due to the car being lowered 60mm on coilovers. Used the 195 45 rear tyres that I had on my Platin's, which still had good tread. Got the local garage to swap the tyres and they have used a load of stick on weights. The new alloys only had a 2 inch weight on the inside rim originally.Drove the car and now the steering wheel shakes between 56 - 80 mphAny ideas ?? Quote Link to comment Share on other sites More sharing options...
Max69vk Posted May 20, 2007 Report Share Posted May 20, 2007 Have you fitted spigot rings? Quote Link to comment Share on other sites More sharing options...
RallyeBaz Posted May 20, 2007 Author Report Share Posted May 20, 2007 Have you fitted spigot rings?Yep.The ride was perfect with the 195 50 tyres fitted. Quote Link to comment Share on other sites More sharing options...
Max69vk Posted May 20, 2007 Report Share Posted May 20, 2007 You've either thrown a weight (which can happen when they use cheap balance weights) or you could have a bent rim. Quote Link to comment Share on other sites More sharing options...
RallyeBaz Posted June 4, 2007 Author Report Share Posted June 4, 2007 Took the wheels to another garage to have them rebalanced. It would seem the original garage's equipment cannot cope with dished rims. The new garage uses the old method of hanging a plum line to get the correct weight. Hand them both redone with only a couple of small weights fitted and they run like a dream. Quote Link to comment Share on other sites More sharing options...
