baldy-andrew Posted October 23, 2006 Report Share Posted October 23, 2006 I removed the rub-strips and it left marks down the length of the car style="vertical-align:middle" emoid=":angry2:" border="0" alt="angry.gif" /> ....it's a bit like the top layer of laquer was taken off with them. Any thoughts on restoration?I also wanted to ask about the sound of the engine...mine is quite whiny/wheezy, is this a querk of the car or a symptom of problems?And finally, style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> , my clutch is rather arkward. With full-lock on, the engine either over-revs or almost stalls...there's no middle-ground. It's quite tricky at junctions and so on but much more noticable with full-lock on.Any advice appreciated. Quote Link to comment Share on other sites More sharing options...
baldy-andrew Posted October 25, 2006 Author Report Share Posted October 25, 2006 style="vertical-align:middle" emoid=":confused:" border="0" alt="confused.gif" /> Bumpy Quote Link to comment Share on other sites More sharing options...
Babs Posted October 25, 2006 Report Share Posted October 25, 2006 I removed the rub-strips and it left marks down the length of the car style="vertical-align:middle" emoid=":angry2:" border="0" alt="angry.gif" /> ....it's a bit like the top layer of laquer was taken off with them. Any thoughts on restoration?I also wanted to ask about the sound of the engine...mine is quite whiny/wheezy, is this a querk of the car or a symptom of problems?And finally, style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> , my clutch is rather arkward. With full-lock on, the engine either over-revs or almost stalls...there's no middle-ground. It's quite tricky at junctions and so on but much more noticable with full-lock on.Any advice appreciated.Have you tried polishing out the marks? If it's definatly laquer, then there's no choice but to get the laquer touched up.What engine do you have? My Sport is tappy on idle, but give it some beans and it starts sounding more "sporty"Check the cable for wear, or it could be a knackered friction plate, or release bearing style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
baldy-andrew Posted October 25, 2006 Author Report Share Posted October 25, 2006 style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Thanks...It is a Sport...but it's less tappy and more whiny.I'll get a bodywork-shop to have a look at the paint. Quote Link to comment Share on other sites More sharing options...
Dubya Posted October 25, 2006 Report Share Posted October 25, 2006 A slight whine under load is normal... Something to do with the breathers. I questioned it with VW UK on my gti before style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
Mitchell Posted October 25, 2006 Report Share Posted October 25, 2006 chances are the cars had paint before and the rub strips were left on hence the raised paint around them,whining noise could be belt tensioner, engine tone difference on full lock is the power steering pump under strain.clutch could be anything really but the pedal boxes are prone to failure "clutch" area. Quote Link to comment Share on other sites More sharing options...
