crooky Posted August 30, 2006 Report Share Posted August 30, 2006 (edited) Right......problem number 3, i got some new blue sidelights for the luposter and i was wonderiing if its a difficult to fit them? as in from the scratch, how to remove the light from the engine bay etc etc? if anyone has a how to then it'l b much appreciated Edited August 30, 2006 by crooky Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted August 30, 2006 Report Share Posted August 30, 2006 Nice and easy.I'll bring in a headlamp and show you where it goes.BRB. Quote Link to comment Share on other sites More sharing options...
crooky Posted August 30, 2006 Author Report Share Posted August 30, 2006 cheers Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted August 30, 2006 Report Share Posted August 30, 2006 Its still raining, once its stopped I'll lift the tarporline and get one in door style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
noddy Posted August 30, 2006 Report Share Posted August 30, 2006 you want me to take a pic as mine are in the house ? Quote Link to comment Share on other sites More sharing options...
nfbr Posted August 30, 2006 Report Share Posted August 30, 2006 Use a flat blade screwdriver, underneath the square conector is a small cylindrical insert which the bulb sits in, put the tip of the driver on the top of the cylinder bit, and rest it on the square connector, gently lever the screwdriver and the sidelight will pop out style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
Mr ColinG Posted August 30, 2006 Report Share Posted August 30, 2006 Use a flat blade screwdriver, underneath the square conector is a small cylindrical insert which the bulb sits in, put the tip of the driver on the top of the cylinder bit, and rest it on the square connector, gently lever the screwdriver and the sidelight will pop out style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />Remember first you will need to open bonnet style="vertical-align:middle" emoid=":D" border="0" alt="biggrin.gif" /> Quote Link to comment Share on other sites More sharing options...
