chrisbwy Posted July 24, 2006 Report Share Posted July 24, 2006 Hi All,How do I remove the black plastic oval shaped insert in the side of the sill?You know the one that gets filled by a black plastic wedge when you shut the door?One of mine is damaged and I want to replace it.ThanksChris Quote Link to comment Share on other sites More sharing options...
Mr ColinG Posted July 24, 2006 Report Share Posted July 24, 2006 If I remember right there is a retaining clip at each end you need to lever it with a screwdriver and the trim should pop out. Quote Link to comment Share on other sites More sharing options...
chrisbwy Posted July 25, 2006 Author Report Share Posted July 25, 2006 Thanks - I'll give it a go.Chris Quote Link to comment Share on other sites More sharing options...
Mike_M Posted July 25, 2006 Report Share Posted July 25, 2006 I just pulled it out when I put my GTI Anni sills on and then pushed it back on again once done. Quote Link to comment Share on other sites More sharing options...
