BlobbyBrown Posted February 13, 2024 Report Share Posted February 13, 2024 Sorry all, Having a bit of a brain melt. Coil Pack has ABCD marked. Does A refer to Cyl 1, B refer to Cyl 2, C =Cyl , D= Cyl 4. or since the cylinder firing sequence is 1342 then A=1, B=3,C=4,D=2 I made the mistake of switching all the spark plugs out at once and now can't get it to fire up. Also what is it with the cables and the metal shrouds around the spark plug end? Normally only ever worked with rubber boots?! Having trouble determining whether they have made contact or not. BTW - 2000 LUPO 1.0 MPI engine (AUC). Thanks Rob Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted February 14, 2024 Report Share Posted February 14, 2024 A - Cyl 1 B - Cyl 2 C - Cyl 3 D - Cyl 4 Quote Link to comment Share on other sites More sharing options...
BlobbyBrown Posted February 14, 2024 Author Report Share Posted February 14, 2024 Thank You. I though that was the answer but not getting any success with this. I managed to break a ceramic fitting on the end of one cable, so just waiting for replacment set. It wasn't starting on 3 cylinders (Cyl 1 missing) and some of the Google images seemed to indicate a different coil pack connection than ABCD = 1234 would assume. Regards Rob Quote Link to comment Share on other sites More sharing options...
