arosatdi75 Posted July 13, 2023 Report Share Posted July 13, 2023 Hello, i have an issue with my arosa 1.4tdi AMF, so i went to change all the fuel line hoses in the engine bay, i've kept the old hose clamps, one of the clamps fell off literally from the tandem pump, the bottom one fell out with the hose, i lost all the fuel in my tank, when i got fuel to start it up, i was cranking it for like 20 30 minutes with few min brakes between cranking, it cranked it worked normally, after few days i went to check the oil level it was waay above maximum, oil and fuel mixed, i've done oil change myself and got new hose clamps and it was great, and i noticed the oil level kinda start to rise again by a little, what could be the issue here, maybe the tandem pump seals went bad or i don't know what happened, i don't know where to start to fix this issue im thinking about to change all the rubber seals on the tandem pump and then check again if it will rise, maybe someone can give me an opinion on this. Quote Link to comment Share on other sites More sharing options...
Rich Posted July 13, 2023 Report Share Posted July 13, 2023 I'm saying tandem pump too. Quote Link to comment Share on other sites More sharing options...
arosatdi75 Posted July 31, 2023 Author Report Share Posted July 31, 2023 update, i've changed all the seals in the tandem pump everything is new so if the oil level will rise again i really don't know whats happening with the engine because i was driving it 2 months before that everything was normal Quote Link to comment Share on other sites More sharing options...
Rich Posted July 31, 2023 Report Share Posted July 31, 2023 Frank would suggest you run the engine with the rocker off and watch the diesel rise from the top of the injector seals into the head. Quote Link to comment Share on other sites More sharing options...
arosatdi75 Posted August 1, 2023 Author Report Share Posted August 1, 2023 update, oil level still rises, i will go next week to change the injector seals and i will hope it will be fixed because this is a headache for me.. first diesel in my life and having problems because of my mistakes but i will fix it still thanks for help Quote Link to comment Share on other sites More sharing options...
