Tomandrew10 Posted July 5, 2023 Report Share Posted July 5, 2023 Hi I recently bought a 2003 lupo 1.7 when I bought it the rear wiper and washer didn’t work, I freed up the motor assembly and the rear wiper worked but putting the pipe back on for the washer it started leaking so I replaced it with some plastic tube. When I tried it with everything connected washer fluid was pouring out of two holes on the fitting (see pictures) into the boot. I bought a new assembly as the wiper was slow and I hoped it would fix the leaking but when I fitted the new one I had the same issue. Has anyone had this issue or know what cause it? Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted July 7, 2023 Report Share Posted July 7, 2023 The metal pipe that goes through the motor can rot away, so all of the water leaks into the motor, both making it leak everywhere and seize the motor up. VW do a repair kit, but it only fits the VALEO motor, 6X0 955 711 F which looks like this Quote Link to comment Share on other sites More sharing options...
