Anyone know the injection timing numbers? SDI
mk2
To set up the injection timing on a VE diesel injection pump, you need to screw in a dial gauge into the output port of the pump.
Then you rotate the engine to TDC and loosen off the injection pump mounting bolts and output pipes.
Using the dial gauge, you adjust the pump until you get the right measurement. But i just can't find it anywhere... Anyone?
Something like 3.22mm or something? Help!
