Stiff First Gear
I bet the cause is worn out gear selector, therefore you actually try to push your gearbox shift rail in position between 3rd and 1st gear. You can pull shifter cover (1) and most probably a lot of parts will be worn out, but part No 11 was gone for mine gearbox. Worn out parts No 54 and 62 makes sideways freeplay as well.
