?spike? Posted July 18, 2020 Report Share Posted July 18, 2020 engine check light is on and these are the faults 3 Faults Found: 17589 - Linear O2 Sensor; Reference Voltage P1181 - 35-10 - Open Circuit - Intermittent 17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1 P1196 - 35-00 - Electrical Malfunction 17586 - Linear O2 Sensor; Pump Current P1178 - 35-10 - Open Circuit - Intermittent Readiness: 0010 0101 looking for a O2 sensor, its for a 1.4 AUA engine, at present it has a sensor with a large plug on it and an additional sensor plugged into the sensor plug, am i right in thinking that this the correct part? and replacing this sensor will clear all three faults? https://www.eurocarparts.com/p/ngk-lambda-sensor-710443985 Quote Link to comment Share on other sites More sharing options...
mk2 Posted July 18, 2020 Report Share Posted July 18, 2020 A few different variants. Get the thing out and take it with you to ECP. Be sure to insist on 20% below their lowest online price.... always cheaper in person Quote Link to comment Share on other sites More sharing options...
?spike? Posted July 18, 2020 Author Report Share Posted July 18, 2020 19 minutes ago, mk2 said: A few different variants. Get the thing out and take it with you to ECP. Be sure to insist on 20% below their lowest online price.... always cheaper in person will do when I look up the part on the vw parts site it says discontinued and an updated part is available, still 5 wire but the additional part is missing from the plug! its also a damn site cheaper! not sure wether to try it and see how it goes? Quote Link to comment Share on other sites More sharing options...
