Hello.
 Can anyone tell me how to replace the parking light bulb in the front of the Seat Arosa lift.
 I tried, but I can't get it out.
 And another question.  To remove the front lamps I have to disassemble the bumper?
They are a pain. I tend to drop the lamp out so I can use long nose pliers. The bumper plastic comes off quite easily. 5 mins once you've done it a few times. There's screws in the slam panel, under the wheel arches and underneath if you've got the undertray fitted correctly.
Posted (edited)
This is what the parking light socket looks like for me.  I bought pliers long 160mm.  I understand that I have to get it somehow and pull it out?
Edited by miodek89
Thanks for the answer 🙂 Pull this protruding part number 1 or the wider number 2?  When I take it out, can it be lightly greased so that it comes out easier later?
