jamie1jamie Posted January 22, 2020 Report Share Posted January 22, 2020 hi was wondering if any one else had had the same problem I have a 1.4tdi lupo now I let it sit for a good few months then took it for an mot it was failed because of the camber on one side wheel went in at the top he told me shocks was bent I knew it wasn't but bought new springs and shocks anyway fitted them all was fine parked it up again for a few months and it is doing the same thing any ideas my brother has my old arosa tdi which dose the same but we know its not bent had the vw from new never been in a crash?? Quote Link to comment Share on other sites More sharing options...
Sausage Posted January 22, 2020 Report Share Posted January 22, 2020 Fronts - loose strut to knuckle bolts that adjust the camber. (undo, pull top of wheel out and tighten). Could be wrong parts fitted like ball joint or arm. Rears - Corrosion or damaged trailing arm / stub axle. Quote Link to comment Share on other sites More sharing options...
jamie1jamie Posted January 22, 2020 Author Report Share Posted January 22, 2020 cheers will try the bolts but didn't think there was any movement in those got the shock from euro car parts could be the wrong one maybe not sure I haven't changed the ball joint or arm yet sorry should have put its the front Quote Link to comment Share on other sites More sharing options...
