Swirleman
Lupo GTi roof gutter rust?
Looking for a Lupo GTi as a fun little runabout
Apparently the roof gutters can show some paint bubbles as water can get trapped in it
There are lots of people saying they got this sorted free on the 12 year rust warranty but that’s gone now as the oldest cars were 2005
What would remedying it involve does anyone know
Presumably if the oxidation occurs from surface water trapped in the channel, it is just superficial and a local smart repair or basic rundown and por15 type diy treatment would suffice maybe?
Remove gutter runners, sand down passed oxidation and respray I’d imagine.
Can just the gutters be resprayed  though or is it all the roof?
and is there a fix to stop it happening again like improvements to the trim strip or something
and do the trims need to come out to inspect it properly and how do they come off exactly so I can inspect it when I look at the car? Thanks
They just pull out. They’re held in place by tapered rubber/metal strips, so if they’ve not been removed they may take a bit of piggling out. And it depends on the spread of the bubbling, but I’d say a sprayer would want to do the whole roof coz it’s be tricky to blow it in across the roof.
I think the minor jiggling of the strips rubs against the gutters and allows to water to get under the paint, the only way to stop that I guess would be to hold the strips in locked solid with some kind of permanent bonding agent.
Thing is with silicone, one of its main selling points is it’s flexible when dry, so you may not be any better off, but tbh once it’s all repair I doubt you’d have any issues for a good few years. Alternatively you could just not refit the strips?
Thanks - what do the plastic strips do exactly then - just cosmetic?
Are the GTis reliable apart from that?  I have another car that is really expensive to run and this one needs to be cheap!
Just cosmetic I’d say when roof bars aren’t fitted maybe. As reliable as owt else, depends on mileage, condition, servicing etc.
