MotorBoatMyGoat
Gap between upper and lower front gti bumper?
Hi. As title really, how do you split the front lower gti bumper from the top? My gti is lowered and I caught the front driver corner on those b*****d square speed bumps. It has caused a noticeable gap to appear between the upper and lower bumper on the driver side.
I basically want to reduce the gap but wanted to know if it's attached by a clip or screw, and whether it can simply be tightened to reduce the gap. Thanks
isnt there some clips that hold the two peices together aswell? i think if you look in the wheel arch there is one? probably not the solution but something i noticed the other day that might help
