henry.0112 Posted April 16, 2017 Author Report Share Posted April 16, 2017 Ok pal ill give it another go when i get chance Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 16, 2017 Report Share Posted April 16, 2017 Pop the ends off first, then it's a rotate up and towards you action, then down, pivoting along the lower front edge. Get a long torx tool in there to remove indicators and grille. The panel does flex a little. I'll take pics when i reassemble in a while. Quote Link to comment Share on other sites More sharing options...
henry.0112 Posted April 16, 2017 Author Report Share Posted April 16, 2017 How do i pop the ends out when i cant get behind them or along the edge? Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 16, 2017 Report Share Posted April 16, 2017 insert thin flat object, like butter knife. not sharp, just strong enough to gently open up a small gap you can spray silicone oil into... then you can direct warm air around the back with a hair dryer to soften the rubber clips. Quote Link to comment Share on other sites More sharing options...
henry.0112 Posted April 16, 2017 Author Report Share Posted April 16, 2017 And then it should just prise out? Quote Link to comment Share on other sites More sharing options...
mk2 Posted April 17, 2017 Report Share Posted April 17, 2017 11 hours ago, henry.0112 said: And then it should just prise out? Well, kinda.... You need to simultaneously rotate the panel forward and down, while gently separating the two clips each side. So begin by working on each end where the panel attaches to the wings. Millimetre by millimetre... Quote Link to comment Share on other sites More sharing options...
henry.0112 Posted April 18, 2017 Author Report Share Posted April 18, 2017 22 hours ago, mk2 said: Well, kinda.... You need to simultaneously rotate the panel forward and down, while gently separating the two clips each side. So begin by working on each end where the panel attaches to the wings. Millimetre by millimetre... Ok thanks for all the help?? Quote Link to comment Share on other sites More sharing options...
