myles983 Posted October 25, 2016 Report Share Posted October 25, 2016 (edited) So i have this fault, which is to do with the throttle body. The issue i have is that that the trottle body is brand new, and has been fitted to a recently fitted engine. Twice in the past three days, the EPC light has come on and this code has come up, and the car has gone into limp mode, even though it is a brand new throttle body. When the throttle body was fitted, it was adjusted with VagCom by the mechanic, and the code came straight back up, but it drove fine. Does anyone have any ideas as to what this could be? Because its driving me insane worrying about when ill lose power next! Thanks in advance, Myles. Edited October 25, 2016 by myles983 Quote Link to comment Share on other sites More sharing options...
Sausage Posted October 26, 2016 Report Share Posted October 26, 2016 Throttle body alignment? I assume the mechanic did that in vagcom: http://wiki.ross-tech.com/wiki/index.php/Throttle_Body_Alignment_(TBA) Otherwise there's this: https://www.obd-codes.com/p0638 Check the wiring plug is good contact for starters though... Quote Link to comment Share on other sites More sharing options...
myles983 Posted October 26, 2016 Author Report Share Posted October 26, 2016 (edited) Thanks for the reply Sausage. I assume hes done the TBA also. How difficult would it be to wire a new plug in ? And how would i go about diagnosing a faulty wire? Multimeter and a wiring diagram with the voltages and impedance on it ? Oh and as soon as the recovery truck dropped me off, Loopy was fine. No EPC light and running normally.... Edited October 26, 2016 by myles983 Quote Link to comment Share on other sites More sharing options...
Sausage Posted October 26, 2016 Report Share Posted October 26, 2016 Pull plug off look for green fluff or signs of corrosion and / or baggy contacts, plug and unplug a few times to scrape the contacts and get a good contact and check the wires for a few inches back from the plug as well for damage, feel the wires for breaks and if they are stiff and non bendy they are probably corroded internally. You might want to try vagcom and see if it shows other codes as some other diagnostic stuff doesnt pick everything up. Google for that code on Lupo and it should come up with something to go on. Quote Link to comment Share on other sites More sharing options...
myles983 Posted October 26, 2016 Author Report Share Posted October 26, 2016 Ok, ill try cleaning off the contacts. I looked at the wires last night, and theyve got a plastic shroud on them, which means its not as easy to check them without removing the shroud. Where does the cable from the throttle body plug into ? In the event it still plays up, couldnt i just buy that section of cables between the throttle body and wherever and use that? As for searching for anything related to a Lupo, i tried in vain last night and only came across situations that were to different to my own to be of any use. Quote Link to comment Share on other sites More sharing options...
myles983 Posted October 26, 2016 Author Report Share Posted October 26, 2016 Oh and i dont have access to VagCom, and dont know anyone who does that wont charge (1800 quid the past 3 months has been spent on Loopy, meaning i have no money till pay day) Quote Link to comment Share on other sites More sharing options...
Sausage Posted October 26, 2016 Report Share Posted October 26, 2016 £5 lead a spare laptop and VCDS lite (can be unlocked to registered version by paying or by a google search) is all you need. I doubt there's any need to dismember the plug, it should be fairly obvious if the contacts are in poor condition. Has the recently fitted engine been running fine prior to this and why was the throttle body replaced? What codes were you getting? if you get VCDS (vag com) up and running you can do the TB alignment yourself if needed and it will probably show up other codes too plus do loads of other stuff with it. Quote Link to comment Share on other sites More sharing options...
myles983 Posted October 26, 2016 Author Report Share Posted October 26, 2016 (edited) 4 hours ago, Sausage said: £5 lead a spare laptop and VCDS lite (can be unlocked to registered version by paying or by a google search) is all you need. I doubt there's any need to dismember the plug, it should be fairly obvious if the contacts are in poor condition. Has the recently fitted engine been running fine prior to this and why was the throttle body replaced? What codes were you getting? if you get VCDS (vag com) up and running you can do the TB alignment yourself if needed and it will probably show up other codes too plus do loads of other stuff with it. Ok, will look into it. Thank you very much. The engine was running fine as far as i know, and the new throttle body was due to misinformation: i was told that the original throttle body was broken after a headgasket replacement, when in actual fact it hasnt been aligned and so wouldnt have worked anyway. So i bought a new one and obviously, it still didnt work. So with the engine swap, the mechanic put the new throttle body on seeing as i had it. Edited October 26, 2016 by myles983 Quote Link to comment Share on other sites More sharing options...
