BigVinny Posted June 8, 2005 Report Share Posted June 8, 2005 Hi Club Lupo,My wife lover her yellow Arosa 1.0S and I do all the servicing for her.There is a slight weep ! around the manual gearbox/transmission and I would like to check the transmission oil level.I know im from the countryside and all that and not very bright, but I cant seem to identify the oil filler bolt which I presume will be on the side somewhere to act as an oil level limiter.Any comments Welcome - Thanks Big Vinny Quote Link to comment Share on other sites More sharing options...
Kid Icarus Posted June 10, 2005 Report Share Posted June 10, 2005 The oil filler plug is a strange design, a VW special. U will need a tool from the dealer to undo it. Its like a star bit design but the centre section has a tiny raised circle. When you know the design its easy to identify on the gearbox. The easiest way to it is from underneath after you take off the plastic tray. I think mine was around a tenner. Quote Link to comment Share on other sites More sharing options...
RobinA3 Posted June 18, 2005 Report Share Posted June 18, 2005 you need a hex key which you can get from halfordshere are a few pics to help you border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> Quote Link to comment Share on other sites More sharing options...
RobinA3 Posted June 18, 2005 Report Share Posted June 18, 2005 border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> Quote Link to comment Share on other sites More sharing options...
BigVinny Posted August 9, 2005 Author Report Share Posted August 9, 2005 you need a hex key which you can get from halfordshere are a few pics to help you border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /> border="0" class="linked-image" /><{POST_SNAPBACK}>Thankyou kid and Robin good advice now im sorted ! Quote Link to comment Share on other sites More sharing options...
BigVinny Posted August 30, 2005 Author Report Share Posted August 30, 2005 17 mm socket torqued to 25 Nm and a splash (0.2l) of fully synth 75W90 and the jobs a good un !Cheers Quote Link to comment Share on other sites More sharing options...
