GeeDub14 Posted March 26, 2016 Report Share Posted March 26, 2016 Had to call out rac due to my cambelt going on my 1.4s lupo, anyone got a rough idea of costs to repair? After being towed home, the recovery guy said he thinks my engine is possibly unsafe .. Soo I'm guessing its going to be good news! Cheers Quote Link to comment Share on other sites More sharing options...
mattarosa Posted March 26, 2016 Report Share Posted March 26, 2016 To do yourself, roughly £80-£100 if it's just the belt. If valves have met pistons it's going to be much more. If you go genuine dealer for a belt change it's £300 Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 26, 2016 Report Share Posted March 26, 2016 Generally the "unsafe" comment regarding your engine was that if the belt broke the valves will hit the pistons. Some engines are "safe" in that if the belt breaks the valves do not hit the pistons, meaning it's no big disaster and cheap and easy to fix. You could slap a new belt on and do a compression test to check for bent valves. You'd need to rotate the engine at least twice by hand as part of the belt installation to make sure the timing is right so badly bent valves would likely show up then as it would be difficult to turn it over. It's going to be expensive unless you can do it yourself or get mates rates from someone you know. You are looking at hundreds of pounds depending on the extent of the damage. Sorry. Quote Link to comment Share on other sites More sharing options...
GeeDub14 Posted March 26, 2016 Author Report Share Posted March 26, 2016 I had feeling that was the case , good job i've just got paid! Thankyou Quote Link to comment Share on other sites More sharing options...
