Gti tdi axles
LexG
Hi
sooooo... I maybe replacing the back beam axle ... Is a tdi back axle the same as a gti axle if I swap the hubs over?????
cheers
Edited by LexG
The GTI rear axle is no wider Only the front is wider, and that's because the ball joints are different.
The different with the GTI rear axle is that it has a strengthening bar inside it.
Good to know, i was going by what i was told by someone who should have known his stuff, but you are correct.
The GTI has the roll bar and the sport doesn't is that the difference?
Saves me looking for a sport beam, if i do a rear disk conversion.....
Yes. And if you buy it complete with the original brake setup then the calipers and carriers will be (or will have been at some point) red. And it may or may not have a funny rubber weight thing bolted to the centre of it.
