THE_NORTON Posted November 10, 2015 Report Share Posted November 10, 2015 HiRecently brought jom blue lines from venom motorsport for my lupo gti, it says fits all except 3L. Were othere kits have different coilovers for the gti/6es for example FK AK Streets ect... just wondered why this is, will it fit fine or is it an over sight? As I see it quite a lot Thanks in advance Quote Link to comment Share on other sites More sharing options...
carrera-gt Posted November 11, 2015 Report Share Posted November 11, 2015 I think it is a problem, I have coil overs and I can't get the camber to factory settings, I have way too much negative which says that the strut is too short overall, I'm planning to strip the suspension off over the winter and replace it.I suggest you try doing the front first, check the strut length of the one you remove before you fit the coilover to make sure they are the same. That way you won't have the same problem. Quote Link to comment Share on other sites More sharing options...
