James_VW Posted April 13, 2015 Report Share Posted April 13, 2015 Looking to programme a new key for the lupo.I only have the single key,Will be using the flip key from the rclick remote central locking key. (Does this already have a immobiliser chip inside or do I need to purchase one?)I could take take the chip from the current key and put in the flip key but I'm wanting a spare.How do i go about it myself?Read online you need the 4 digit code which can be gained by using software called vagtacho??Can you also programme the new key with vagtacho or do you need VCDS? (I have the freeware version of VCDS) Quote Link to comment Share on other sites More sharing options...
Skezza Posted April 14, 2015 Report Share Posted April 14, 2015 X reg or personalized plate? Quote Link to comment Share on other sites More sharing options...
James_VW Posted April 14, 2015 Author Report Share Posted April 14, 2015 Its a v reg, old style dash etc. Quote Link to comment Share on other sites More sharing options...
Skezza Posted April 14, 2015 Report Share Posted April 14, 2015 Its a v reg, old style dash etc. OK, theoretically possible then. It'll be Immo2. You need a VAG-TACHO and a full VCDS. I won't tell you how to do that, but you don't necessarily need to pay. Then you get your SKU from VAG-TACHO, and use it to enter the adaptation mode on VCDS. Adapt your key, and you're sorted.You will need to buy an immobilizer chip yes. Quote Link to comment Share on other sites More sharing options...
DentedRims Posted April 17, 2015 Report Share Posted April 17, 2015 On this subject, are all Lupos immo2? Mines a Y-2001 and I also only have one key and wanting another (remote one) + the emergency key! I'm not overly keen about paying £50ish for just the remote part but I would resent paying another £50+ for the key blade then half to one hours labour at the dealership to do a 10 minute job of coding it in! You can get the blades off eBay for a few ££'s but without a RFID chip (but with a hole for a glass/needle style one), am I right in thinking I could use any needle type immo 2 chip and code this and my original key to my car using the 4 digit SKC through VAGCOM? (isn't there a square plastic type too? Which keys will I find the correct glass ones in?). Thanks Quote Link to comment Share on other sites More sharing options...
DentedRims Posted April 17, 2015 Report Share Posted April 17, 2015 Just re-read the post and it seems skezza has already answered part of my question!!! How do I tell if it is immo2 or immo3? Also any idea on where to get a new chip from? Quote Link to comment Share on other sites More sharing options...
Skezza Posted April 17, 2015 Report Share Posted April 17, 2015 (edited) Hard to tell if Immo2 or Immo3 without getting the immobilizer out and looking, but some basic factsAll GTI are Immo3, so when I talk about Lupo's I mean all NON-GTi's...Pretty much all Lupo's Before 2001 are Immo2Some Lupo's in 2001-2002 are Immo3Every Lupo after is almost certainly Immo3.Immo2 is easy enough to make a key for using VAG-TACHO and VCDS. Immo3, much harder, almost certainly a dealer job unless you can get them to give your SKU, which they won't. Edited April 17, 2015 by Skezza Quote Link to comment Share on other sites More sharing options...
DentedRims Posted April 18, 2015 Report Share Posted April 18, 2015 Cool thanks, just been looking at the Ross tech wiki! On a do the check tomorrow to see which immo I have. Fingers crossed for immo2 ;-) Quote Link to comment Share on other sites More sharing options...
