1.4 16v 100bhp misfire/stuttering when cold
Hi guys - any advice welcome here.
As the title says, only does when cold. Scanner came up with front lambda fault which i then replaced with a known good genuine VW item.
Car now runs better but engine light comes straight back on each time its turned off. It now shows a slightly different code to do with front lambda circuit?
Are there any know places where the wiring loom has problems? Or maybe the ECU?
Cheers
