Sergio Posted May 27, 2014 Report Share Posted May 27, 2014 Hi all,Can anyone give any advise as to why the switch on the driver's side for the passenger window allows me to move the window up but not down. Also, the driver side window sometimes sticks/goes back down instead of up. Is it just a case of needing a replacement motor for both?Thanks in advance. Quote Link to comment Share on other sites More sharing options...
deeplupo Posted May 27, 2014 Report Share Posted May 27, 2014 Switches are renowned for failing mate. Looks like its a new switch buddy. Silly expensive from VW so best off going second hand.I have a passenger going live on ebay tonight if you need one. Drop me a PM. Quote Link to comment Share on other sites More sharing options...
db247 Posted May 27, 2014 Report Share Posted May 27, 2014 Mine does the same. From the passenger side all good, from my side, no joy. I can only bring it back up. I thought it was related to the central locking playing up, but that was based on nothing except for coincidence! Quote Link to comment Share on other sites More sharing options...
stator Posted May 27, 2014 Report Share Posted May 27, 2014 It could be that only one of the switches has failed and is always stuck in one direction. Unfortunately the connectors are different on the Drivers and Passenger side switches Try disconnecting each switch and seeing if the other one works on it's own Quote Link to comment Share on other sites More sharing options...
