Jamesstrutt Posted April 24, 2014 Report Share Posted April 24, 2014 There is probably a thread somewhere on this, but i cant find a detailed one. Anyway i am looking at removing the front indicators for tinting. Anyway on the top of the grill there are two torx screws that i have undone, but there looks to be another fixing somewhere that i can't find. can anyone help me out on this? Quote Link to comment Share on other sites More sharing options...
Hawkey52 Posted April 24, 2014 Report Share Posted April 24, 2014 i done this the other day, the two indicators are held on by a single screw behind them on the top, if you feel around for a bit you will see them.. they are quite awkward to get to although these are the only two screws then the will just pull out (also with a bit of a fiddle)Max. Quote Link to comment Share on other sites More sharing options...
Jamesstrutt Posted April 24, 2014 Author Report Share Posted April 24, 2014 Hi thanks for the help. And do you mean the single screw above the indicator, directly on top? if so i have found that. When i undo that, the indicator seems to be stuck to the bodywork surrounding it even tho the screw is removed. i have had a look behind it and cant really see any other screws. how long did it take you to remove yours? cheers. Quote Link to comment Share on other sites More sharing options...
Hawkey52 Posted April 25, 2014 Report Share Posted April 25, 2014 that should be it.. it took me about 20 mins but 15 0r that was undoing the screws in the nasty place... they have a small location pin at the bottom that keep them in.. they shouldnt be stuck wither so if you pull it back and upwards the pin should come out. i applied some tint and it is best to take them out and do it deffo! Quote Link to comment Share on other sites More sharing options...
Jamesstrutt Posted April 25, 2014 Author Report Share Posted April 25, 2014 Ok cheers, I'll have a look tomorrow. Hopefully I will get them out. Quote Link to comment Share on other sites More sharing options...
Hawkey52 Posted April 25, 2014 Report Share Posted April 25, 2014 yeah they should just wiggle out.. mine did Quote Link to comment Share on other sites More sharing options...
Jamesstrutt Posted April 27, 2014 Author Report Share Posted April 27, 2014 (edited) Found the second screw in the nasty place and got it out. When you put them back in did you remove the grill? as getting the screw in the hole is a pain, as its in such and awkward place to get at. And you can only just get your hand in there. anyway its deffo worth the effort i think. Edited April 27, 2014 by Jamesstrutt Quote Link to comment Share on other sites More sharing options...
Hawkey52 Posted April 27, 2014 Report Share Posted April 27, 2014 i think i did take it out, i dont remember those screws... prehaps mine didnt have them in haha Quote Link to comment Share on other sites More sharing options...
Jamesstrutt Posted April 29, 2014 Author Report Share Posted April 29, 2014 Ok cheers, and yea it's hard to explain. Will look good with my new coilovers. Just need some wheels now. Quote Link to comment Share on other sites More sharing options...
