GeoScars Posted March 27, 2014 Report Share Posted March 27, 2014 What amp would i need to wire 6x9, plus my sub to the one aMP? Quote Link to comment Share on other sites More sharing options...
Dblock Posted March 27, 2014 Report Share Posted March 27, 2014 Most vague question ever. Like literally useless without knowing the impedance of the sub and 6x9's dvc or not? How much power do they need?Also don't be a 90's chav by fitting 6x9's. Quote Link to comment Share on other sites More sharing options...
GeoScars Posted March 27, 2014 Author Report Share Posted March 27, 2014 210watt for the 6*9, then he sub is 1000 watt... Dvc I have no idea.. 90's Chav Im not I just wanna wire them up because I've had them for awhile and not done anything with them Quote Link to comment Share on other sites More sharing options...
Dblock Posted March 27, 2014 Report Share Posted March 27, 2014 Rms power not peak. Peak means nothing. Need to know the ohms of the too. Quote Link to comment Share on other sites More sharing options...
GeoScars Posted March 27, 2014 Author Report Share Posted March 27, 2014 55 RMS to 210 I believe the sub is 400 rms Quote Link to comment Share on other sites More sharing options...
Dblock Posted March 27, 2014 Report Share Posted March 27, 2014 Ok still need to know the resistance. Quote Link to comment Share on other sites More sharing options...
GeoScars Posted March 27, 2014 Author Report Share Posted March 27, 2014 theres the speaker 6X9 specs Speaker System 3-way-triaxial Diameter (mm) 6 Inch x 9 Inch Rated Power Handling 55 watts Maximal Power Handling 260 watts Sensitivity (2.83 V/m) 92 dB Frequency response 40 - 22,000 Hz Impedence 4 ohms Cone Material Injected PP Installation Depth 73mm Sub is FLI Trap FT-12 Single 12" 1000W Active Bass EnclosureRMS Power:300WPeak Power: 1000W Quote Link to comment Share on other sites More sharing options...
Mini_ash Posted April 9, 2014 Report Share Posted April 9, 2014 the sub will have its own amp you will need a 2channel amp for the 6x9 somthing like 500w they are cheap (£20) you will need a power block to power both amps or you can run 2 cables Quote Link to comment Share on other sites More sharing options...
GeoScars Posted April 14, 2014 Author Report Share Posted April 14, 2014 Thank you!, Any ideas of a better sub to buy and install? also Ill look for those two channel amps t Quote Link to comment Share on other sites More sharing options...
