Danyutz
Help with spacers
I know the BBS 772 tuck like crap and I need some spacers, but i don't know which size to go - tires are 195/45 15, planning for 30mm drop and i want the wheels as close to the fender as possible, but without rubbing.
Can anyone suggest sizes?
Thanks!
Measure the gap between the tyre and the arch, go a few mm less.
Anything under 15mm and you'll have to get basic, non hubcentric, slip on spacers.
I'm in the dark now, what's the difference between basic and hubcentric?
Hubcentric sits on the hub then bolt onto the hub, you then bolt the wheel onto the spacer. They also make hubcentric that sit on the hub that require long bolts but I personally don't trust these as much (Also a lot less hassle getting the first type) Then there are spacers that just sit on the hub and bolt between the hub and your wheel. It is possible to have wheel centering problems if you get too thick of these type.
