Cigarette lighter issue
cheesey
Hi guys wonder if someone could help me out with this one
The issue is the light behind it works but the lighter itself doesn't, which is abit of a pain when trying to hook your sat nav up to it, I know it's probably an easy fix just not sure where to look to sort out the problem.
If anyone can shed some light on the problem it would be much Appredicted
Edited by cheesey
under steering wheel, they'll be like a black section of plastic, bout 6" long, and at the top it's got a handle, just pull it out.
then hopefully you've got a diagram card for the fuse number
Thanks for the info mate will take alook the moro nd hopefuly get it sorted
Isn't something like this usually shared with another feature on the car ie horn?
Edited by cheesey
