Golf tdi injectors on a lupo tdi?
  • 3 months later...
Do the 130/150 injectors provide more injection. I'm not sure about any wiring but I'm sure they fit IIRC they are in the A2's 1.4TDi
If you were to do it, you would have to remap it to get it to fuel right. otherwise you would have a lot of smoke.
A2 is 90hp as it does also have a vnt turbo where ours is wastegated. Theirs is kkk where ours is garret too, so it isn't a straight swap. four branch from one of the lager vnt PDs, cut one branch, weld shut and fit it (not sure if actually fits) and change the N75 and in vagcom to enable the audi 90hp's file to use the vnt.
