wall-e Posted May 13, 2013 Report Share Posted May 13, 2013 Hi guys.We've just tried to fit an aftermarket headunit to our 1.4 16v Lupo, but seem to be without any radio reception.I used a little aerial adaptor to hook the antenna up, but something tells me I needed a special adaptor?The one I have is like this:http://ashbycarelectronix.co.uk/images/uploads/Aerial_adaptor.jpgIs this the jobbie I need?http://www.ebay.co.uk/itm/New-VAG-Aerial-Booster-Amplified-Antenna-Lead-VW-Cars-/370813112841?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item56562f1209Thanks Quote Link to comment Share on other sites More sharing options...
Skezza Posted May 13, 2013 Report Share Posted May 13, 2013 Correct, that is the adapter you need at least for the adapter you already. However, you don't need to buy that particular version, you can buy one that has the correct plug on the end.Unfortunately, I forget the product code. If you trawl through my posts I talk about it somewhere. I'll have a look when I get chance. Quote Link to comment Share on other sites More sharing options...
ma11b Posted May 14, 2013 Report Share Posted May 14, 2013 You will need both parts the second will go on the in car ariel loom blue wire to 12v feed the the first link attaches in between the black connector and into the back of the cd player Quote Link to comment Share on other sites More sharing options...
Skezza Posted May 14, 2013 Report Share Posted May 14, 2013 You will need both parts the second will go on the in car ariel loom blue wire to 12v feed the the first link attaches in between the black connector and into the back of the cd playerYou don't, you can get one with the pin built in. I have one in my Lupo. I just can't remember the product code. I'll look through my emails now 1 Quote Link to comment Share on other sites More sharing options...
Skezza Posted May 14, 2013 Report Share Posted May 14, 2013 Just found my old post, the adapter you want is the PC5-90. I quote my original post below From here : http://forums.clublupo.co.uk/index.php?/topic/91810-aerial-booster-switched-live/?p=1061511 Quote Link to comment Share on other sites More sharing options...
wall-e Posted May 14, 2013 Author Report Share Posted May 14, 2013 (edited) Cheers for the help guys, just ordered a PC5-90 from ebay.With a bit of luck it'll be as simple as pulling the head unit back out and fitting that part Do you recommend any particular tray to sit underneath where we have a CD player from the BETA system (or gamma) I forget? Edited May 14, 2013 by wall-e Quote Link to comment Share on other sites More sharing options...
Skezza Posted May 14, 2013 Report Share Posted May 14, 2013 (edited) Cheers for the help guys, just ordered a PC5-90 from ebay.With a bit of luck it'll be as simple as pulling the head unit back out and fitting that part Do you recommend any particular tray to sit underneath where we have a CD player from the BETA system (or gamma) I forget?An original coin tray + cup holder is pretty good but they go for quite a lot on eBay (£30 usually) plus there aren't that many around.http://www.ebay.co.uk/itm/Toyota-MR2-Celica-Double-Din-Pocket-Cup-Holder-Starlet-/230592901070?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35b0686fce - cheap alternative Edited May 14, 2013 by Skezza Quote Link to comment Share on other sites More sharing options...
wall-e Posted May 15, 2013 Author Report Share Posted May 15, 2013 Thanks bud, thats quite a good second option, but for the sake of keeping everything matching I'd go for the VW one Quote Link to comment Share on other sites More sharing options...
ma11b Posted May 15, 2013 Report Share Posted May 15, 2013 You don't, you can get one with the pin built in. I have one in my Lupo. I just can't remember the product code. I'll look through my emails now You would need both parts if you didnt have the all in one cable though. Dont really need the booster though unless you have a tiny ariel or listen to mw or am. Quote Link to comment Share on other sites More sharing options...
Skezza Posted May 16, 2013 Report Share Posted May 16, 2013 You would need both parts if you didnt have the all in one cable though.Dont really need the booster though unless you have a tiny ariel or listen to mw or am.I listen to MW Quote Link to comment Share on other sites More sharing options...
