Trx 33 Posted May 6, 2013 Report Share Posted May 6, 2013 Right, i have known for a while now that the spoiler fouls on any non GTI but i bought a spoiler regardless, i have just test fitted it to find out the extent of the fouling on a polo 6R aerial and it is quite significant, even on the shorter aerial. Has anyone found a fix for this because i have just thought would it be possible to just put/weld a spacer on the hinge stop to restrict the range of the boot travel? Quote Link to comment Share on other sites More sharing options...
JoeA Posted May 6, 2013 Report Share Posted May 6, 2013 Without seeing the angles involved, do you think it would still foul a shark fin? that may be your answer... Quote Link to comment Share on other sites More sharing options...
Trx 33 Posted May 6, 2013 Author Report Share Posted May 6, 2013 I think there is a possibility, ill go see if i can get i couple of pictures of how it is at the moment Quote Link to comment Share on other sites More sharing options...
Trx 33 Posted May 6, 2013 Author Report Share Posted May 6, 2013 Boot fully open without antennaHow it would be with antenna attachedHow far spaced it needs to be to be able to clear antenna Quote Link to comment Share on other sites More sharing options...
