VAG com and Fog lights
Hello
Is there anyone in the Hampshire area that has a VAG com and is willing to meet up as i have just bought a Lupo 3L and i would like to check it out.
Also im converting it to UK spec and im wondering if the VAG will help-
My prob is that the car has bulbs in both sides for the rear fog light, however as it is left hand drive only the left (NS) one works, fo UK the right one (OS) should work.
Im wonering if VAG com can change this in settings?
or
Shall i just have to run a wire from one side to the other, MOT man said if both come on it will pass, if OS one doesnt it will fail
Any help appreciated in advance
Edited by rick briddon
You'll need to run a wire over. The RHD lupos only have one fog light wire going up to the OS rear. There is no cable going to the NS rear.
  • 9 months later...
You shouldn't need to cut, just extract the existing cable from the connector then splice onto it. Or leave it in place and run the cable over and have two fog lights.
