RobbHancock Posted July 26, 2012 Report Share Posted July 26, 2012 sooo...was going round a roundabout on monday, just normally and then the engine completely died...managed to roll to a lay-by on the side of the dual carriage way luckily. Towed it to the nearest garage and they say it's the camshaft AND the crankshaft sensors gone...they say it costs about £80 + VAT each for the sensors...that doesn't include labor or anything! Personally, i think thats a bit steep as i had a quick look on tinterweb and found them for no more than £40 including VAT?! So was just wondering if anyone has a 1.4 V-reg Arosa SE (pre-facelift) that i could grab the part no. from for both of these sensors so i can make sure i dont order the wrong thing....cheers guys! Quote Link to comment Share on other sites More sharing options...
craigg!! Posted July 26, 2012 Report Share Posted July 26, 2012 I know the crank sensor is about 80+vat. I could find you the part numbers tomorrow when I'm at work if you could give me your engine code. Quote Link to comment Share on other sites More sharing options...
steved Posted July 28, 2012 Report Share Posted July 28, 2012 Good luck with fitting that what a major jobRemove the inlet manifold and wedge back to the bulkheadunbolt water housing from the side of the headPull out thelong water pipe under the inlet manifoldRemove starterThen you should be able to see the sensor (you will need a ball end allen key) Quote Link to comment Share on other sites More sharing options...
