MrSupercrazy Posted June 28, 2012 Report Share Posted June 28, 2012 noticed over the last few days the car seems to cut out randomly, its usually when ive just gotten in and im reversing or when i pull up to lights, also found that when i use the elec window switch, the headlights dim if there on.Any ideas? Quote Link to comment Share on other sites More sharing options...
Brad1992 Posted June 29, 2012 Report Share Posted June 29, 2012 dodgey alternator? If not vagcom ya car, see if anything comes up, might be a lambda sensor as thats to do with emissions Quote Link to comment Share on other sites More sharing options...
DarkStryder360 Posted June 29, 2012 Report Share Posted June 29, 2012 There are a million threads if you search for this. Most common answer is: have you cleaned out your Throttle Body? Quote Link to comment Share on other sites More sharing options...
MrSupercrazy Posted June 29, 2012 Author Report Share Posted June 29, 2012 cheers guys, will give the TB a clean if that fails will have to go get it vag com'd Quote Link to comment Share on other sites More sharing options...
polariskid Posted June 29, 2012 Report Share Posted June 29, 2012 Mine has these exact same problem I shall also try this Quote Link to comment Share on other sites More sharing options...
Brad1992 Posted June 29, 2012 Report Share Posted June 29, 2012 mine did it, took my throttle body off to clean it and there was aboutt an inch of gunk built up on it so worth a check! Quote Link to comment Share on other sites More sharing options...
