Loudinho Posted June 20, 2012 Report Share Posted June 20, 2012 I fitted a set of FK coilovers on saturday and put both front and back right down to the lowest setting, i then decided yesterday i needed to go about an inch higher so i jacked up the front and i heard a knock at the rear and the spring had come out, when fitting the rear there was a large washer and bolt that went underneath the adjustable part to hold it in as many of you will know, i noticed that this was missing!!i realise that this is obviously needed just wondering how badly!? and if so where could i get some new ones, as both have come out and i defenatly put them both on tightly!?!? Quote Link to comment Share on other sites More sharing options...
Ashh Posted June 20, 2012 Report Share Posted June 20, 2012 I'd replace it for sure, as the spring cup could become unseated, which would be an obvious problem. Ring supplier and get a new one or find out their measurements and get one from b and q or something Quote Link to comment Share on other sites More sharing options...
