Trout13 Posted March 4, 2012 Report Share Posted March 4, 2012 Got a 2001 1.4L lupo but it has a very heavy gearbox. Had the pedal box done recently and they said the clutch would need done at some point as it is quite heavy. Would this cause the stiff/heavy gear box. It is stiff in all gears and they do not seem very positive when you select them. Is the problem more likely to be the two gear linkage cables?How easy is it to replace the gear linkage cables and how much do they cost. If it is not too much I would replace them first to see if that solved the problem before going to the expense of doing the clutch.Any help appreciatedTrout13 Quote Link to comment Share on other sites More sharing options...
Turna29 Posted March 4, 2012 Report Share Posted March 4, 2012 Ive got the same problem mate. I was told to put gearbox oil in, made a bit of difference but not a great deal. Will be interesting to here what the cures are.Ash Quote Link to comment Share on other sites More sharing options...
Liam-R Posted March 6, 2012 Report Share Posted March 6, 2012 Change gearbox oil and reset your linkages. There's a video on YouTube. Just search resetting vw gear linkages. Takes about 2 mins! Hope this helps Quote Link to comment Share on other sites More sharing options...
Trout13 Posted March 6, 2012 Author Report Share Posted March 6, 2012 Cheers for that Ill give it a go at the weekend. Dont think it will be as easy trying to do that under the car. Quote Link to comment Share on other sites More sharing options...
Liam-R Posted March 6, 2012 Report Share Posted March 6, 2012 You don't need to go under the car mate. I do my TDi with bonnet open and leaning in Quote Link to comment Share on other sites More sharing options...
LupoEnvy Posted March 7, 2012 Report Share Posted March 7, 2012 Sorry if this is way off the mark - before you do anything else, you might just want to quickly check the clutch cable is tight. At the end of the cable (in the engine bay) are a couple of bolts. Mine came loose a while ago and I thought I needed a new clutch! Tightened them up and everything was fine. Might be totally off the mark, but worth checking before getting mucked up! Quote Link to comment Share on other sites More sharing options...
