Dan_Moores Posted November 6, 2011 Report Share Posted November 6, 2011 Hi all,Noticed recently my lupo's driver side shaft is leaking a the joint to the gearbox. From what I've research on the internet I think the seal may need changing to solve the problem.Can anyone tell me if I'm correct and how much money I'm talking as from what I've found the seals aren't too expensive!Cheers Quote Link to comment Share on other sites More sharing options...
Steve TDI Posted November 7, 2011 Report Share Posted November 7, 2011 If you undo all the bolts round the drive shaft, the outer bit will come away.Now you should see an Allen key. Tighten that up. If it is tight, then yeah, you might have to change the seal. Quote Link to comment Share on other sites More sharing options...
