lupojo66 Posted September 27, 2011 Report Share Posted September 27, 2011 Hi AllI have a 1.7SDI 1999 TIt is fitted with a momo wheel and boss. I want to put it back to a standard steering wheel. Will any lupo steering wheel fit? It did have a non airbag steering wheel on so can i fit an airbag wheel and just have the airbag inactive?I hope that all makes sense lolMany thanks in advance for any helpcheersJo Quote Link to comment Share on other sites More sharing options...
madmanncfc Posted September 27, 2011 Report Share Posted September 27, 2011 HelloAny lupo wheel should fit and you may well have some wiring for the airbag behind the wheel as people often put in resistors to fool the car into thinking the airbag is still connected.If you dont have the wiring its not an issue as the wheel will still physically fit the car.Hope that helpsChris:-) Quote Link to comment Share on other sites More sharing options...
jake-riddett Posted September 27, 2011 Report Share Posted September 27, 2011 i could always supply you with a steering wheel? could swap? pm me. Quote Link to comment Share on other sites More sharing options...
lupojo66 Posted September 30, 2011 Author Report Share Posted September 30, 2011 thanks madmannpm sent jake Quote Link to comment Share on other sites More sharing options...
lupo_jack Posted September 30, 2011 Report Share Posted September 30, 2011 I have a aftermarket wheel aswell but the airbag wire snapped on me so basically i now have only a little bit of the cable without the connection on the end :/ do i just put the resistor across each wire? Quote Link to comment Share on other sites More sharing options...
