Jessicar Posted April 27, 2011 Report Share Posted April 27, 2011 (edited) My boyfriend wanted me to put his car up on here to see if anyone was interested, after a lot of persuasion, I finally agreed. So this is his ad:MOT until FEB 2012TAX until end of JuneMILES: 108600The car has a standard B18C6 engine, lowered 40mm on springs and shocks (make unknown - done by a previous owner) which gives a nice compromise between standard and coilovers. The gearbox is smooth through all gears at all RPM. The car came with a barryboyish big bore exhaust; it now has a standard exhaust including the Cat (the other exhaust can be supplied with the car if you want it.) It has a Kevlar "Whale Penis" induction. HIDs. Red Recaros with head cushions. HPI clear. Sub woofer. Gearbox lock. Anti-car jacking door locksSince I've owned the car, it has had the following work done:-- New front wheel bearings- New CV joints- New discs and pads- currently has 4 new tyresBad Points:-- Speedo doesn't work, possible VSS. I've always used my RoadAngle thing- For last MOT it needed welding around seatbelt anchors, unfortunately they burnt through to the outside of the car making the paint flake - see pictures- Horn does work but the button for the Momo steering wheel is missing, so inoperative- Wheels could do with a refurbish. None of them are scraped but corroded- Front bumper is stone chipped and doesn't fit absolutely perfectly - see pictures- Rear bumper has hairline cracks in the paint, only really noticeable if you're looking- Odd dint here and there, comes with the age of the car- It has had a slight bump on the front at some point in its life (cosmetic only), repaired to a high standard and for whatever reason wasn't reported (before I owned the car)Please note I'm trying to be as honest as I can and the above notes reflect in the priceNo test drives without the appropriate insurance.Any Questions please call Oliver on 07540 743 975, I don't have signal at work so you can ring after 6 or text me in the day and I'll ring you when I get home from work.Offers around £3500By all means feel free to ask me anything and I'll try to answer it! Edited April 27, 2011 by Jessicar Quote Link to comment Share on other sites More sharing options...
