bikemad04 Posted November 21, 2010 Report Share Posted November 21, 2010 Recently the passanger window will only go about 75% down, Works ok otherwise goes up and down, but just doesnt go all the way down any ideas? Cheers. Quote Link to comment Share on other sites More sharing options...
treblet Posted November 21, 2010 Report Share Posted November 21, 2010 You haven't just changed the speakers in your doors by any chance? Quote Link to comment Share on other sites More sharing options...
bikemad04 Posted November 21, 2010 Author Report Share Posted November 21, 2010 Nope but the window rubber at the top has split and when doing the window up it goes slow bebcause the rubber is stopping it, so maybe doing that for a while has broken something? Quote Link to comment Share on other sites More sharing options...
TestArosa Posted November 21, 2010 Report Share Posted November 21, 2010 Recently the passanger window will only go about 75% down, Works ok otherwise goes up and down, but just doesnt go all the way down any ideas? Cheers.I had a similar problem after the door stay got disconnected, it turnd out the window was catching on the stay (which normally it would miss). It looks like you need to get inside the door to see whats blocking it. Good luck. Quote Link to comment Share on other sites More sharing options...
bikemad04 Posted November 22, 2010 Author Report Share Posted November 22, 2010 I had a similar problem after the door stay got disconnected, it turnd out the window was catching on the stay (which normally it would miss). It looks like you need to get inside the door to see whats blocking it. Good luck.Thanks will take a look Quote Link to comment Share on other sites More sharing options...
