Rowan
Oil change on gti
Oil service light is on and want to do the change at home. Iv bought the oil and filters, could someone tell me where the engine oil sump plug is located. Any help appreciated.
Cheers Rowan
bottom/back of the sump
you will have to remove the engine/poop shield
if its still there,to access the sump nut
The sump plug nut should be a 19mm socket or spanner to undo it.
Oil service light?
The oil light is for oil pressure as far as II'm aware and if that's on it's nt a good sign I'd not be driving tht around!!
The 'service oil' warning comes on with a timer, it might be that your oil doesn't actually need changing, but that whoever changed the oil last time didn't reset the timer.
