lowgti Posted October 2, 2010 Report Share Posted October 2, 2010 hi allgot abit of a problem with the gti,the abs light keeps coming on then it will go off but the brakes seem to be binding on,makes a real weird noise and the pedal keeps pushing back.going to put it on vag com next week,just wondering if anyone else has had the same problem?cheers Quote Link to comment Share on other sites More sharing options...
BEP51 Posted October 2, 2010 Report Share Posted October 2, 2010 hi allgot abit of a problem with the gti,the abs light keeps coming on then it will go off but the brakes seem to be binding on,makes a real weird noise and the pedal keeps pushing back.going to put it on vag com next week,just wondering if anyone else has had the same problem?cheersthe car will do this every so often, you just have to drive a few hundred metres and it tests your brakes (the weird nose etc). then it recalculates the abs system and lets you continue normally, if the brake binding stops after the light goes off then dont worry, its fine. Otherwise if the brakes stay binding, have it looked at. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted October 2, 2010 Report Share Posted October 2, 2010 (edited) Sounds like an issue relating to signal fault from one of the wheel speed sensors. ABS controller thinks the wheel is locking so pulses the pedal.Could be the sensor, pickup ring, controller or wiring. Good money it will be a sensor which is around £8 on eBay, but you need VAG-COM to tell you which one it is.Others have had this issue. Edited October 2, 2010 by 99hjhm Quote Link to comment Share on other sites More sharing options...
lowgti Posted October 2, 2010 Author Report Share Posted October 2, 2010 thanks guys Quote Link to comment Share on other sites More sharing options...
jonnykell1980 Posted October 3, 2010 Report Share Posted October 3, 2010 the pedal shouldnt give you any sort of pushing back unless the abs is cutting in. from what your describing i would agree youve got a problem with a pick up ring or sensor. its giving a signal saying a wheel is locking up when its not and the abs is working when it shouldnt. vagcom should fault it or it may need an oscilloscope reading on all sensors to check the wave forms and see which is not right. Quote Link to comment Share on other sites More sharing options...
lowgti Posted October 3, 2010 Author Report Share Posted October 3, 2010 the pedal shouldnt give you any sort of pushing back unless the abs is cutting in. from what your describing i would agree youve got a problem with a pick up ring or sensor. its giving a signal saying a wheel is locking up when its not and the abs is working when it shouldnt. vagcom should fault it or it may need an oscilloscope reading on all sensors to check the wave forms and see which is not right.cheers mate,il get onto it next week. Quote Link to comment Share on other sites More sharing options...
