nfbr Posted December 27, 2004 Report Share Posted December 27, 2004 (edited) This is probably one of the easiest "Technical" Jobs to do on the lupo, but to some people, fitting a CD Player can be a Daunting experience! I have created this guide to hopefully help make it a nice Pleasant experience for anyone who attempts this job themselves!Here you see a standard vw head unit. Looks ok, sounds ok... but we want better than that don't we?? Step OneUsing a set of release keys (I used some old kenwood ones pushed in at a downward angle) slot them into the holes either side of the head unitStep TwoStick a finger into the cassette flap, the unit should come out with a gentle tug, if not, try adjusting the position of your keysStep ThreeSlide the unit out (watch the corners dont scrape your dashboard) and release the two plugs on the back of the unitStep FourIf your head unit has a trailing lead clip this into the VW ISO radio plugs you see below,Step FiveTry and tuck away as much of the wiring as possible now, this will help when you come to slide the head unit in to position.Step SixSlip your ISO / Or trailing lead through the cage along with the aerial leadand slide the cage into position. On most cages you'll need to bend a few tabs using a screwdriver, to secure the cage. (alpine kindly provide a self securing cage which makes the job a doddle)Step SevenConnect the ISO / Trailing lead to the head unit, and connect the aerial lead, Now slide the unit into the cage, but before you slide it all the way in, turn it on and test everything is working ok.Step EightOnce you know the unit is working properly, Slide it all the way in and you should hear it click into position(Unfortunately my camera battery ran out so i cant show you a picture of what it looks like fully fitted. but you get the idea)FAQ - QuestionDo VW use a different wiring method to usual ISO looms?AnswerYes, In order to get my head unit working i found I had to swap the red and the yellow wires over (making both circuits permanent live) to get the unit to work.PM Me for a more detailed approch to doing this, or seek advice from your local Car Audio shop (not halfords cos they'll sell you an adaptor)QuestionMy aerial doesnt fit to my head unit?AnswerVW use the European Standard aerial plug, Many aftermarket head units dont use this type, To solve this problem you can buy an aerial adaptor (£4.29 @ Halfords) (£3 to £4 from local car audio shops) Edited January 20, 2010 by nfbr Cleaned by: nfbr. 1 Link to comment Share on other sites More sharing options...
