lupohillman Posted June 21, 2010 Report Share Posted June 21, 2010 How do you remove the aerial, the rubber bit on the bottom of mine has split and fell off.cheers Quote Link to comment Share on other sites More sharing options...
Mike_M Posted June 21, 2010 Report Share Posted June 21, 2010 Remove pillar trim and rear grab handles to be able to gently bend and lower the roof lining. Once down unplug the aerial and use a 22mm scanner to remove the base nut.......done Quote Link to comment Share on other sites More sharing options...
Scotty1.4 Posted June 21, 2010 Report Share Posted June 21, 2010 Remove pillar trim and rear grab handles to be able to gently bend and lower the roof lining. Once down unplug the aerial and use a 22mm scanner to remove the base nut.......doneYeah what Mike said, go easy on the roof lining, dont damage it. Quote Link to comment Share on other sites More sharing options...
lupohillman Posted June 23, 2010 Author Report Share Posted June 23, 2010 Sounds easy enough, thanks. Quote Link to comment Share on other sites More sharing options...
