john_p Posted April 25, 2010 Report Share Posted April 25, 2010 (edited) Got a strange problem with the electric windows, 2003 LupoBasically from the drivers side switches, neither window will go downI've taken the switch holder out and swapped them over, no differenceThe passenger window goes up and down from the passenger side switch, and goes up fine from the drivers side switch. I can hear the windows trying to go up when I press the switches up, so I assume it's only downward motion affected. Is it possible that both drivers side switches fail at the same time? Or is there another common link eg. cabling between door and car.. Edited April 25, 2010 by john_p Quote Link to comment Share on other sites More sharing options...
arney Posted April 25, 2010 Report Share Posted April 25, 2010 iv got the same problem check your fusses iv replaced my drivers switches and the window regulater that work for all of one day now its doing the same but only with the driver window apprently it could be the plug on the motor im goin to have a look tomorro. Quote Link to comment Share on other sites More sharing options...
john_p Posted April 26, 2010 Author Report Share Posted April 26, 2010 Yeah fuses are fineI think I'll replace the switches first as one definitely doesn't feel as smooth as the otherBit odd that they both fail at the same time though .. and both in the same direction Quote Link to comment Share on other sites More sharing options...
grayg40 Posted April 26, 2010 Report Share Posted April 26, 2010 yes they could pos go at same time. try disconnect the swicthes and get a peice of wire and short them out so you are working them manually. if that doesnt work its not the switch. Quote Link to comment Share on other sites More sharing options...
