Auq Engine Questions
lupoGT
Hi,
Does anyone know if you can use auq drive by wire with original lupo throttle pedal?
Will i have to use auq 20vt clocks / ignition / keys for this conversion or is there a way around this?
Does the ecu have to be defeated?
Thanks
AUQ is drive by wire IIRC. The only 20v transverse engine that uses cable is the AGU. You can get your immobiliser defeat by jabbasport, think they do a package to remove it and remap the ecu at the same time for something like £400?
You should be able to use the lupo dbw pedal for the 20v engine, see no problem there as long as the throttle position sensor on lupo pedal box is compatible. You intending to go OEM wiring though? Aftermarket gives you lots of options, see www.qpeng.com for details.
