bensgod Posted January 11, 2010 Report Share Posted January 11, 2010 (edited) sorted now Edited January 20, 2010 by bensgod Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 11, 2010 Report Share Posted January 11, 2010 Yes, just swap over, bleeding brakes is the same with ABS. Quote Link to comment Share on other sites More sharing options...
bensgod Posted January 11, 2010 Author Report Share Posted January 11, 2010 Yes, just swap over, bleeding brakes is the same with ABS.ah ok, would it be the rear beam or axle that would be bent, i know you cant really say because you havent seen it but what would it most likey be from a rear wheel impact, the wheel is currently sitting like this \---|thanks again Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 11, 2010 Report Share Posted January 11, 2010 ah ok, would it be the rear beam or axle that would be bent, i know you cant really say because you havent seen it but what would it most likey be from a rear wheel impact, the wheel is currently sitting like this \---|thanks againYes rear beam/axle, same thing. Quote Link to comment Share on other sites More sharing options...
bensgod Posted January 11, 2010 Author Report Share Posted January 11, 2010 alright, cheers best get looking then! Quote Link to comment Share on other sites More sharing options...
CasperGTI Posted January 11, 2010 Report Share Posted January 11, 2010 Might have just bent the stub axle, which seperates from the rear beam.Its likley that youve bent both bits, But check it out before you go changing the rear beam, it will be cheaper for a stub axle.John Quote Link to comment Share on other sites More sharing options...
bensgod Posted January 11, 2010 Author Report Share Posted January 11, 2010 Might have just bent the stub axle, which seperates from the rear beam.Its likley that youve bent both bits, But check it out before you go changing the rear beam, it will be cheaper for a stub axle.Johnok, once i get it home tomorrow ill strip it down and have a gander! Quote Link to comment Share on other sites More sharing options...
Bigfoot Posted January 12, 2010 Report Share Posted January 12, 2010 stub axles are about £25-£30 brand new from GSF, don't know how much they are from vw Quote Link to comment Share on other sites More sharing options...
lupoluke Posted January 12, 2010 Report Share Posted January 12, 2010 There are about £90 from stealers pall. Quote Link to comment Share on other sites More sharing options...
