Stamfordblue Posted May 11, 2009 Report Share Posted May 11, 2009 hi i need some help or advice lowing my lupo. its a 16v sport i have a coil over kit put it on about a year ago and its been off the road coz it needed a pedal box just done that so its going back on the road. i need some help leveling it out its realy high at the back and toooo low at the front does the back only go down a curtain amount? any help would be greatthanks Quote Link to comment Share on other sites More sharing options...
mike89 Posted May 11, 2009 Report Share Posted May 11, 2009 the back doesnt go very low, normally, depends what make you have. Vmaxx, ta technix etc dont go very low. If you want the back lower, take the adjuster ring out. This will lower it quite a bit more. If you want it even lower take the full adjuster block out and set the spring on the platform. Hope this helps Quote Link to comment Share on other sites More sharing options...
Stamfordblue Posted May 11, 2009 Author Report Share Posted May 11, 2009 i have a jamex kit Quote Link to comment Share on other sites More sharing options...
mike89 Posted May 11, 2009 Report Share Posted May 11, 2009 im pretty sure its the same as the ta technix (phil j) an vmaxx. take the adjuster rings out first and see what it looks likemike Quote Link to comment Share on other sites More sharing options...
Stamfordblue Posted May 12, 2009 Author Report Share Posted May 12, 2009 im pretty sure its the same as the ta technix (phil j) an vmaxx. take the adjuster rings out first and see what it looks likemikehi i have do that it only brings it down about half a cm and the other side is still lower just wondering if my springs are right they say avo4r on them but on some pics the spring is around the other way to what i have them but the adjuster wont fit if i do it that way. what shall i do now? Quote Link to comment Share on other sites More sharing options...
lupoluke Posted May 12, 2009 Report Share Posted May 12, 2009 take the adjuster out . Quote Link to comment Share on other sites More sharing options...
Stamfordblue Posted May 12, 2009 Author Report Share Posted May 12, 2009 i have done everything suggested now and its still the same but one side is lower than the other, so not sure what to do are the springs wrong? Quote Link to comment Share on other sites More sharing options...
mike89 Posted May 12, 2009 Report Share Posted May 12, 2009 is the ground level? lol mine sit slightly lower on one side, wen its on my driveway Quote Link to comment Share on other sites More sharing options...
Stamfordblue Posted May 12, 2009 Author Report Share Posted May 12, 2009 [yes the ground is level i think the springs are wrong,the springs have 10 coils the springs in all the photos ive seen have 8 Quote Link to comment Share on other sites More sharing options...
daz phimo Posted June 10, 2009 Report Share Posted June 10, 2009 [yes the ground is level i think the springs are wrong,the springs have 10 coils the springs in all the photos ive seen have 8i have the same coilover kit as you and i only have 8 coils 3 are tight and 5 are spaced. the tight coils go to the top. they should only go in one way. Quote Link to comment Share on other sites More sharing options...
