littleredarosa Posted May 5, 2009 Report Share Posted May 5, 2009 as above im new to the arosa and lupo scene i have just bought a modified arosa with a gearbox fault but i would like to do an engine swap but i whant to keep it simple and easy and as cheap as possible as i would like abit more power than a 1ltr if any one could help that would be great cheers courtney Quote Link to comment Share on other sites More sharing options...
littleredarosa Posted May 6, 2009 Author Report Share Posted May 6, 2009 anyone? Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted May 6, 2009 Report Share Posted May 6, 2009 Yours is a 1.0 yes?Polo GTI engine is pretty straight forward if your car already has electronic throttle?The 1.4s are obviously just as straight forward.You basically gonna need :Engine and gearbox.Complete wiring loom, clocks and ECU if you can (make sure they cut the bulk head from the shell and not the loom from the bulk head!) Electronic GTI throttle body if you have this, or cable throttle body from older Polo GTI if you have cable.Drive shafts are the same.Engine mounts are the same.Most of the wiring is the same, so you could get away with just the engine and box, and pay £1000 - £1500 for an aftermarket ECU supplied, fitted and mapped and stick with your standard loom if you struggle to find a suitable donor car. Quote Link to comment Share on other sites More sharing options...
littleredarosa Posted May 6, 2009 Author Report Share Posted May 6, 2009 ok sounds sweet do you no ruffly how much i would have to pay for a shop to do the transfer? Quote Link to comment Share on other sites More sharing options...
